Admin
Visto por última vez: Hace 8 años 8 meses
Feather Plucking A Major Problem for the African Grey Parrot
Feather plucking is famous to be always a very unpleasant habit of the african grey bird. They are famous feather pluckers. It's said that the Timneh African Grey parrots aren't as bad since the Congo African Grey Parrots when it comes to feather plucking. But this isn't an established fact.
Why do birds pluck their feathers to begin with any bird owner must ask himself. There are numerous different reasons for this nasty habit. The African grey parrot is much attention that is needed quite by a parrot species from his human owner. If this doesn't occurs then a bird will likely get bored and this may lead to feather plucking. But belive me that the this feather plucking problem is very complicated because it's very difficult to eliminate it. There have been once the african greys plucked their feathers due to dealing with much attention cases. So you just don't know just how to take care of your chicken. Dietary fluctuations, or environmental problems may also take to feather plucking. Some environmental dilemmas might be smocking very much in the area where in fact the parrot is kept or keeping him in an area with dry air. Also is recommended for african gray parrots to have regular baths or to come in contact with some sort of moist air. The african dull parrots should not encounter any frightening activities because this may take to feather plucking.
If this unpleasant practice appears in you bird's day to day activities than you should first visit a veterinarian. He'll probably attempt to find a physical explanation for the bird's problem. It's best to try to comprehend what the veterinarian explains and try to locate some ways of handling the situation. It's confirmed that the african gray bird is the most intelligent species. His higher degree of intelligence, along side possible incorrect early socialization at the breeders and maybe not knowing the birds mental needs when it becomes a companion parrot frequently contributes to neurotic habits -- such as for example pulling.
Their feathers weren't plucked by timnehs african grey parrots up to the congo african grey parrot. This could be since they were whilst the congo african bird not as common. For their duller coloration these were never as licked as the congo.
In as they are very difficult birds to take care of conclusion the feather plucking is really a serious problem for the african grey parrots.
Here is more information in regards to home page check out http://africanmangoplusstore.com/african-mango-diet-pill/
